it's always subject to deletion cuz as stated above there may be no benefit of having the setting where you earn an extra man at an earlier point. If there is no benefit to the change then why should it be deleted?mahlemiut wrote:The rule says "is subject to deletion", which to me, says that there is a possibility that it could be deleted, not that it will be for sure
Now if you were on your last life prior to the higher extra man setting then yes it should be deleted/DQ'd cuz they are benefitting from getting the extra man earlier.
...so this is one you can't decide on unless you watched the inp and see when he loses his lives.
Why did he have it set like that? Well, perhaps he set it like that when first playing the game...and he finally improved to the point of having a score to submit...but had forgotten to go back to default settings.
My opinion is if no benefit from the change in settings, then it's moot and no consequences should happen from that...no action taken.
