Page 2 of 5
Posted: Sun Feb 09, 2003 5:39 am
by Frankie
FLYBALL - Hmmm, can someone tell me if its possible to play the computer in this game? I can only get it to act like a 2 player game. If no one knows I'll ask Pat to archive the game.
Posted: Sun Feb 09, 2003 7:07 am
by diabolik
Frankie wrote:FLYBALL - Hmmm, can someone tell me if its possible to play the computer in this game? I can only get it to act like a 2 player game. If no one knows I'll ask Pat to archive the game.
Yes, you are right, this is a 2 player game only. No problem with archiving it.
Posted: Sun Feb 09, 2003 3:55 pm
by Frankie
diabolik wrote:Yes, you are right, this is a 2 player game only. No problem with archiving it.
Allright, it's been archived. Thanks for the help.
Posted: Fri Feb 14, 2003 9:27 pm
by Frankie
JITSUPRO - Game with Mercy Rule where you can't continue. Deleted all recordings as none of them was a full game of 9+ innings. BTW, this game ends by Mercy Rule when you have a 9 points lead, and not 10 points.
Posted: Sat Feb 15, 2003 8:52 am
by Frankie
KOSHIEN - Game with Mercy Rule where you can't continue. All recordings except Phil Lamat's deleted, because they ain't a recording of a full 9+ innings game.
KOUYAKYU - This game got its own Scoring System.
Posted: Sat Mar 01, 2003 10:22 pm
by Frankie
DPLAY -
Game without Mercy Rule that allow to continue. It was decided in a poll that we only play one inning in this game. Special Rules updated.
EINNINGS -
Game without Mercy Rule that allow to continue. Same as DPLAY.
The poll can be found here:
viewtopic.php?t=10093
Posted: Sat Mar 22, 2003 10:01 pm
by Frankie
KYUKAIDK - Game with Mercy Rule where you can't continue. All recordings online deleted, because none of them was recordings of full matches 9+ innings. Special Rules updated.
KYUKAIDO - Game with Mercy Rule where you can't continue. Same as KYUKAIDK.
Posted: Sun Apr 13, 2003 6:08 am
by Frankie
MJLEAGUE - I can't get this game to start, it crashes every time no matter what version of MAME I use. I've asked Chad, and it does the same for him. Can someone get this to start? I guess the game will have to be archived.
EDIT: More information about this game below.
Posted: Sun Apr 13, 2003 11:28 am
by Kale
Frankie wrote:MJLEAGUE - I can't get this game to start, it crashes every time no matter what version of MAME I use. I've asked Chad, and it does the same for him. Can someone get this to start? I guess the game will have to be archived.
You need to use mame .36 to get this working...
Posted: Sun Apr 13, 2003 2:24 pm
did try mame36 with no luck... i do have ascreen shot for it so i must have been able to play it at one point (or maybe just used the wip pictures...)
***EDIT*** oh hey frankie i didn't work in XP for me but it does work in win98 with and without sound.
Posted: Sun Apr 13, 2003 4:23 pm
by Frankie
MJLEAGUE - Indeed, you must use Mame 36 to play this game, and wow, it lets you play a whole game on one credit. Besides that, it got its own scoring system.
Thank you guys for your help.
Posted: Sat May 03, 2003 8:39 am
by Frankie
PC_BBALL - Game without Mercy Rule that allow to continue. All recordings deleted as none of them was a full game of 9+ innings.
PC_BSTAR - Game with Mercy Rule where you can't continue. Also all recordings deleted because none of them was full games of 9+ innings.
Posted: Sun May 18, 2003 7:47 am
by Frankie
RELIEF - Game with Mercy Rule where you can't continue. Had to delete all the uploads for this game, as none of them was a recording of a whole 9+ innings game. If you want to submit for this game, you must choose to play 'Starting Pitcher - 9 Inning Game', and insert a coin after each inning.
RELIEF2 - Game with Mercy Rule where you can't continue. Same as RELIEF.
Frankie NO!!!
Posted: Sun May 18, 2003 1:02 pm
by CMP
Relief Pitcher falls into Championship Baseball, as with it's OWN SCORING MECHANISM, if you want a full game, SPLIT THE GAME DONT DELETE
EVEN THEN, IT HAS ITS OWN SCORING MECHANISM FOR THE 9 INNING GAME AS WELL, SO EVEN THEN IT WOULD FIT INTO Championship Baseball with it's OWN scoring mechanism.
Posted: Sun May 18, 2003 2:58 pm
by Frankie
Well the way it is now is definately better than your uploads (assuming you are Chris Parsley), where you play one run to win the game, and then so on.
If you want it split, ask Pat.
If you like to keep the money earned system, which I have my doubts about then run a poll.
And all that yelling is not of much help
