Baseball Update.
Frankie
Post by Frankie »
FLYBALL - Hmmm, can someone tell me if its possible to play the computer in this game? I can only get it to act like a 2 player game. If no one knows I'll ask Pat to archive the game.
Frankie
diabolik
Post by diabolik »
Frankie wrote:FLYBALL - Hmmm, can someone tell me if its possible to play the computer in this game? I can only get it to act like a 2 player game. If no one knows I'll ask Pat to archive the game.
Yes, you are right, this is a 2 player game only. No problem with archiving it.
Frankie
Post by Frankie »
diabolik wrote:Yes, you are right, this is a 2 player game only. No problem with archiving it.
Allright, it's been archived. Thanks for the help.
Frankie
Frankie
Post by Frankie »
JITSUPRO - Game with Mercy Rule where you can't continue. Deleted all recordings as none of them was a full game of 9+ innings. BTW, this game ends by Mercy Rule when you have a 9 points lead, and not 10 points.
Frankie
Frankie
Post by Frankie »
KOSHIEN - Game with Mercy Rule where you can't continue. All recordings except Phil Lamat's deleted, because they ain't a recording of a full 9+ innings game.
KOUYAKYU - This game got its own Scoring System.
Frankie
Frankie
Post by Frankie »
DPLAY - Game without Mercy Rule that allow to continue. It was decided in a poll that we only play one inning in this game. Special Rules updated.
EINNINGS - Game without Mercy Rule that allow to continue. Same as DPLAY.
The poll can be found here:
viewtopic.php?t=10093
Frankie
Frankie
Post by Frankie »
KYUKAIDK - Game with Mercy Rule where you can't continue. All recordings online deleted, because none of them was recordings of full matches 9+ innings. Special Rules updated.
KYUKAIDO - Game with Mercy Rule where you can't continue. Same as KYUKAIDK.
Frankie
Frankie
Post by Frankie »
MJLEAGUE - I can't get this game to start, it crashes every time no matter what version of MAME I use. I've asked Chad, and it does the same for him. Can someone get this to start? I guess the game will have to be archived.
EDIT: More information about this game below.
Frankie
Kale
Post by Kale »
Frankie wrote:MJLEAGUE - I can't get this game to start, it crashes every time no matter what version of MAME I use. I've asked Chad, and it does the same for him. Can someone get this to start? I guess the game will have to be archived.
You need to use mame .36 to get this working...
did try mame36 with no luck... i do have ascreen shot for it so i must have been able to play it at one point (or maybe just used the wip pictures...)
***EDIT*** oh hey frankie i didn't work in XP for me but it does work in win98 with and without sound.
Frankie
Post by Frankie »
MJLEAGUE - Indeed, you must use Mame 36 to play this game, and wow, it lets you play a whole game on one credit. Besides that, it got its own scoring system.
Thank you guys for your help.
Frankie
Frankie
Post by Frankie »
PC_BBALL - Game without Mercy Rule that allow to continue. All recordings deleted as none of them was a full game of 9+ innings.
PC_BSTAR - Game with Mercy Rule where you can't continue. Also all recordings deleted because none of them was full games of 9+ innings.
Frankie
Frankie
Post by Frankie »
RELIEF - Game with Mercy Rule where you can't continue. Had to delete all the uploads for this game, as none of them was a recording of a whole 9+ innings game. If you want to submit for this game, you must choose to play 'Starting Pitcher - 9 Inning Game', and insert a coin after each inning.
RELIEF2 - Game with Mercy Rule where you can't continue. Same as RELIEF.
Frankie
CMP
Frankie NO!!!
Post by CMP »
Relief Pitcher falls into Championship Baseball, as with it's OWN SCORING MECHANISM, if you want a full game, SPLIT THE GAME DONT DELETE
EVEN THEN, IT HAS ITS OWN SCORING MECHANISM FOR THE 9 INNING GAME AS WELL, SO EVEN THEN IT WOULD FIT INTO Championship Baseball with it's OWN scoring mechanism.
Frankie
Post by Frankie »
Well the way it is now is definately better than your uploads (assuming you are Chris Parsley), where you play one run to win the game, and then so on.
If you want it split, ask Pat.
If you like to keep the money earned system, which I have my doubts about then run a poll.
And all that yelling is not of much help :)
Frankie
