Page 9 of 10
Re: Shinobi - tips, tricks, faq
Posted: Fri Sep 28, 2012 4:04 am
by ben.shinobi
destructor wrote:I can say that playing with F10 key on stage 2-1 is much easier than normal play. Without F10 key, player is more tired.
Not really, is true that the credit time is longer in real play (10min more) but I'm not more tired. When I play on pcb, I can make little pause between leeching lives (go to toilet. smoke cigarettes...) because I use autofire lock...
Posted: Fri Sep 28, 2012 11:51 pm
by dan
ben.shinobi wrote:Yes is true but you could easily ask the same question to Syno...
I think he only found one big secret (that maybe nobody have found) that I don't show in my last inp. This secret is not reveal at the moment simply because we work on it at the moment. Don't worry Des, every shinobi players will know very soon...
Why?
I have told you his reason already.
And now, whether he has the secret is your mere assumption.
ben.shinobi wrote:
Could you tell us the top score history before the first score you write (760.090 GMC-ALECK-ALX--- PCB) ??
638730 TYRAN-CHA
671,840 GAT
689,800 GAT
702,110 JAG-AXIO
718,570 GMC-ALECK-ALX
(Uncertain)
Posted: Sat Sep 29, 2012 6:36 am
by destructor
I say about playing with MARP rules.
Not really
Really, and you have more time in day for more tries.
Posted: Wed Oct 03, 2012 7:18 am
by ben.shinobi
Posted: Wed Oct 03, 2012 10:23 am
by BBH
Why an old version of MAME where the romset is different?
(or at least, whatever I have doesn't seem to work...)
Posted: Wed Oct 03, 2012 1:28 pm
works with 0.87 roms
shinobi.a4 65536 CRC(b930399d)
shinobi.a1 65536 CRC(343f4c46)
epr11283 65536 CRC(9d46e707)
epr11281 65536 CRC(7961d07e)
shinobi.b9 65536 CRC(5f62e163)
shinobi.b10 65536 CRC(75f8fbc9)
shinobi.b11 65536 CRC(06508bb9)
epr11290.10 65536 CRC(611f413a)
epr11294.11 65536 CRC(5eb00fc1)
epr11291.17 65536 CRC(3c0797c0)
epr11295.18 65536 CRC(25307ef8)
epr11292.23 65536 CRC(c29ac34e)
epr11296.24 65536 CRC(04a437f8)
epr11293.29 65536 CRC(41f41063)
epr11297.30 65536 CRC(b6e1fd72)
shinobi.a7 32768 CRC(2457a7cf)
shinobi.a8 32768 CRC(c8df8460)
shinobi.a9 32768 CRC(e5a4cf30)
Posted: Sun Oct 07, 2012 4:30 pm
by ben.shinobi
847.430 pts :
http://benjamin.bouloch.free.fr/shinobi ... s086u3.zip
Almost perfect patterns I know on every stages (all 1k pts hostage). For higher score, it must use Lobster secret (4-4) but I don't find any safe pattern.
Posted: Tue Oct 16, 2012 10:38 pm
by TRB_MetroidTeam
GHEMANT wrote:...After TRB discover:...
Hi guys! I know I didn't do many things here, however I am very happy in helping the gaming community, showing and sharing my INP. Thanks and good luck!!!
Posted: Mon Oct 29, 2012 6:57 pm
by ben.shinobi
Posted: Wed Oct 31, 2012 2:02 pm
by shinobiXboX360
Impressive score Ben! 848.660 pts (Final Boss actual).
Posted: Wed Oct 31, 2012 3:58 pm
by ben.shinobi
Thanks a lot man !!
Please give me your advice about patterns used. If you see something I can improve, please tell me !! I'm sure that you have different leeching patterns ? especially about 5-1, I'm still wondering if it's the best possible patterns ? About Lobster, (4-4), I can't find safe pattern for special bonus.
Posted: Sat Dec 15, 2012 7:23 am
by ZeroMax
No pattern for Lobster yet?
I got safe one to around 40-50 shoots but it's really hard to count em unless i monitor their address in cheat engine with W.
Here what i do to get to 40-50 shoots. Might eventually make a video clip if you can't do it but i doubt.
Upon start fire 7-10 shoots and stop holding the stick Up. Holding up is vital cos boss charges straight towards u and pushes u back, if you don't hold up you get stabbed by sword. But if you do hold up you avoid the sword somehow
that's 100% to start the boss everytime.
Then he withdraws backwards you can still fire shurikens on him, the boss charges two times towards you and swings with swords. Those 2 times you can avoid the sword by just jump before it swings-that's also 100%. After every swing he withdraws back few steps you can use the time to fire shurikens, you can even shoot him when he charges towards you but don't shoot when you jump. Cos if you hit im in the head the pattern is lost and he starts charging towards you pushes you back and kills you(lever up) won't save this time
So if you do all correct after initial charge and 2 swing charges you will get to around 40-50 shoots.So far this is 100% safe and then i got stuck and can't find safe way to continue.
I even managed to jump over it few times but its very tricky timing and it's not 100% and running away from him and counting shots is very hard...
Posted: Wed Jan 09, 2013 4:49 pm
by ZeroMax
861,230 pts - 2013.02
That's the Lobster Special bonus i bet
Posted: Wed Feb 27, 2013 9:31 am
by ben.shinobi
I've worked this morning on the Lobster pattern. I've found this:
http://www.dailymotion.com/video/xxtnq4 ... videogames
This is very risky but I almost sure that Syno use this pattern for his last Arcadia score.
To be sure that Musashi goes through Lobster, perfect timing is required. Most important thing is distance between musashi and Lobster when you hit his head. I've tried with save and is possible to get the pattern every time if timing is correct. I'm sure that I can beat Arcadia's Syno score but I work on many other games now.
Maybe Syno could share something about the Lobster pattern ?
Posted: Thu Mar 07, 2013 3:44 am
by ZeroMax
Very nice find Ben, i tested with part of my pattern and i managed to get the 20.000 bonus, but i used magic.
Maybe if i find software i'll make little clip and show here.
In short i jump over Lobster while I'm on the left side and then i go to right corner, then
instead of depending on timing the shot i use magic right when lobster is near me.
Magic pushes him back to the distance needed to charge you and fall bellow that's 100%.
I score around 5000 pts less, but im using cheats to monitor the shuriken count .
Yet it involves a bit of luck...
