Must see recordings
Wednesday's Tengai replay is great. He finishes the game on one credit:
Vertex-B's kangaroo recording is very impressive:
http://marp.retrogames.com/inp/c/2/4/rg ... olf106.zip
Mark Brzozowski scores 2.4m on omega race:
http://marp.retrogames.com/inp/6/f/2/wa ... olf101.zip
- destructor
Links are not worked. Maybe someone have these replays on HD?zlk wrote:This player knows how to play Guwange:
http://www.geocities.jp/pkbst331/
Here is a direct link to the replay section:
http://www.geocities.jp/pkbst331/replay.htm
There is a 40 million point replay, a 50 million point replay, and a 2 players at the same time replay at the site. I enjoyed watching them all.
http://emureplay.web.fc2.com/replay.htm for the guwange replays.
- destructor
http://www.geocities.co.jp/SiliconValley-Oakland/8859/
EDIT.
In inp folder I have guwange.inp and guwange.hrp
I use:
hcmamep -rompath c:\roms -playback guwange.hrp
Playback incorrect.
I copy hrp file to hrp and nvram folder, still the same.
Where is key?
EDIT
hcmamep -rompath c:\roms -playback guwange.inp
or
works incorrect too.
EDIT.
I use:
Playback incorrect.
Where is key?
EDIT
or
$ ./mame71u20726.exe -playhrp gensuke
failed to open gensuke for playback
$ ./mame71u20726.exe -playhrp gensuke.inp
nvram: ignore nv file
REPLAY: "guwange (Guwange (Japan))"
recorded by "HaChiMAME "
WARNING: "HaChiMAME 0.71u2 (Jul 26 2003)" may not play back this hrp file correc
tly. [press return]
cpu[0]: M68000 C core
Average FPS: 57.550327 (872 frames)
- destructor
I playbacked on WinXp with no problem.GHEMANT wrote:these replay work with windows 98 only if I remember well.
In zip file must be inp and hrp files. Unzip both to Inp folder. Use playhrp, not playback.
Wait, I will check gensuke replay. I watched sisin replay.
EDIT
OK. Gensuke replay works fine too.
What I did:
1. unzip guwange-gensuke to Inp folder. Now I have guwange-gensuke.inp and guwange-gensuke.hrp in Inp folder.
2. in maind hcMAME directory I create a.bat file. Inside bat file I write:
hcmame -rompath c:\roms -playhrp guwange-gensuke
3. Run a.bat file.
Chad wrote:Code: Select all
$ ./mame71u20726.exe -playhrp gensuke failed to open gensuke for playback [/quote] Probably you don't have gensuke.hrp file. And, inp and hrp file must have the same name.
destructor wrote:Chad wrote:Code: Select all
$ ./mame71u20726.exe -playhrp gensuke failed to open gensuke for playback [/quote] Probably you don't have gensuke.hrp file. And, inp and hrp file must have the same name.[/quote] thanks, des, they work now. It doesn't work with the .inp at the end you must remove the .inp and also make sure you say -playhrp with the same filename removing the .inp extension (none of the zips uncompress to gensuke.inp and gensuke.hrp so the correct commandline would be after extracting the inp and hrp to the inp folder. ./mame71u20726.exe -playhrp guwange-gensuke ./mame71u20726.exe -playhrp guwange-2p I was disappointed that the two player wasn't a cooperative effort but a keyremapped single player using two players, but still great recordings.
Destructor's new MARP world record on Shinobi, CONGRATS!
http://marp.retrogames.com/r/shinobi
(I assume it beats TG and Gamest records)
I remember being the first one to finish the game at my arcade back in the day...but it was so much easier since we didn't know about 50k bonuses. Getting those bonuses requires some seriously accurate timing.
- destructor
