yes, i was able to playback arx and jfa's to their advertised scores with the hiscore.dat provided. Upon further investigation, these recordings playback perfectly if everything in hiscore.dat BUT the gunbird entry is REMOVED. If the gunbird entry in hiscore.dat is changed by a bit, these recordings do not playback. I believe newer mames do away with the hi files and use the hiscore.dat for storing hi's and of course the emulations use hiscores as part of the random seeds and the seeds are thus not stored in the inp file so these inp won't playback with out the same seeds fed in at playback as were there when recording. and guess what happens when you set the hiscore during a recording, the inp you just made will never playback unless you remembered what the hiscore.dat had there previously.
gb9: I move that we treat hiscore.dat as nvram files, they must be deleted before recording, this should come to a vote pretty soon.
LAST CALL on gunbird recordings
I've had a little muck around with hiscore.dat now.
I tried to see if it made any difference with Thunderforce AC, which it didn't. It didn't make any difference whether there was a .hi file present or not. In fact, it does not use it at all when using -playback.
Now, I am looking through the MAME source to see if there is anything noticable regarding hiscore.dat itself.
BBH, your recording played back fine for me with sound disabled, so long as hiscore.dat was present. Without hiscore.dat, it craps out pretty much instantly. In neither case, no gunbird.hi file was used or created. My playback script moves .hi files anyway, but I am pretty sure MAME ignores them anyway when playing back a recording.
just for completing this issue, all three top recordings can be played back with the hiscore.dat, i was able to playback with DOS mame57 and sound off bbh's recording, the others played back with mamew and sound on.
But the vote will be in a week or so after i do some more testing and i get a full agreement from the remaining editors.
