I told you I would be back.....My new problem is when I try to run some games such as Dungeons and Dragons Tower of Doom, the screen just goes black and is unresponsive. I downloaded it from a differenct source just to double check and ran an audit and it says the game is working. I have downloaded other games that do work so its in the right place and all that good stuff.
By the way, Im using the newest version of mame32
I hope you all dont get tired of hearing my rookie problems, but everyone has been helpful so far.
ill_com95@yahoo.com
yet another mame32 question
For how long is the screen unresponsive? D&D is a quite a large
romfile if I remember correctly (10meg+ I think) it may take some
time to start it up.. (Just a guess)
Maybe its a version of D&D that is still not working? Barry R should
be the guy to talk with about those kind of things (Protections)
Otherwise I have no idea what´s wrong.
Regards
QRS
qrs@telia.com
Regards
QRS
qrs@telia.com
Usually, that is caused by mismatched XORs (files used to 'decrypt'
the program ROMs. If you still have that commandline version of
MAME, then open a DOS box, go to the folder containing mame.exe, and
type 'mame ddtod -verifyroms' (without the quotes, of course). If
any come up with a Wrong CRC error, then you may have the ROMs for a
different revision or region. Note that the Asian version 'ddtoda'
has not yet been decrypted. I have tried the US version (ddtod)
which works perfectly for me.
It may help if you tell us your system specs too, as that my help.
bsr@hnpl.net
bsr@hnpl.net
Im not exactly sure what you meant by the command version of MAME,
but if its the one thats for windows but not MAME32 then I deleted
it. The version of TOD that I have downloaded is the US version, when
I check the properties it says its working and the ROM check passes
when I run an audit.
I was also thinking along the lines as you when you asked about my
computer, its probably too old and slow for the good games.
Pentium200 with 96megs of ram.
ill_com95@yahoo.com
ill_com95@yahoo.com
Ah, it could very well be a CPU speed issue then. Something in the
range of 400-500MHz is better suited for CPS-2 games. You could try
disabling sound though, as that can give a nice speed boost.
bsr@hnpl.net
bsr@hnpl.net
