WORLD HEROES problems with 1st position
Actually the first position in Marp is played on wolfmame 144. This version is totally different from the others (I use 106 usually): the damage is totally different. If you use down+weak kick in wolf 144 you can see a incredible damage versus all characters. In wolf 106 the damage is normal / original. All this make incompatible these 2 versions, the old replay by me and Moreno use wolf 95. Any reason?
Only "wh1" rom have this strange super damage. Other romset "wh1h and wh1ha" are normal.
Haze
Re: WORLD HEROES problems with 1st position
Post by Haze »
wh1 is the original arcade release
wh1h / wh1ha are the version most commonly found on AES home carts (but sometimes 2nd run arcade or bootlegs) they're a newer code revision.
presumably the bug was identified in the original game and later fixed.
as far as MARP goes it sounds like the replays just need to be associated with the correct sets (naming changed at some point)
Yep :
0.120: Johnboy added World Heroes (set 1). Fully redumped (set 2), this is verified AES version. Changed description of clone 'World Heroes (set 2)' to '(set 3)'. Changed 'World Heroes (set 1)' to clone '(set 2)'. Renamed (wh1h) to (wh1ha) and (wh1) to (wh1h).
So all pre-120 inputs have to be moved.
Fixed
Is the first case of AES / MVS version totally different in gameplay. My question is:
the old wh1 (aes version) exist also in MVS in some part of the world?
Haze
Post by Haze »
they inevitably ended up on MVS carts, either officially or unofficially. As we can't be 100% sure on the 'officially' bit they're put as clones rather than being the parent.
whenever I saw the game in arcades here when it was new in 1992, it was the version with higher damage. I distinctly remember thinking how stupid it was that Brocken could take pretty much an entire lifebar out just doing rapid crouching light kicks. Never saw a version with lower damage.
ok, after some research... both MVS version exist officially (some users have set 1, other have set 2). Set 1 (with big damage Broken) is common, set 2 with low damage is uncommon. However there are tons of differences... in set 1 some combos not work, special moves are slow....
Both versions are original MVS carts and probably exist 2 versions also in AES ROM. The same for many other neo geo games. There are again some games in 2 versions not available in mame, exemple Blue's Journey.
Despatche
Post by Despatche »
I question why MAME is (sensibly) using an older version as the parent when they seem very adamant about using whatever the latest version they can find is. Even if wh1h is for a "home console", the AES is not a home console at all and it should be treated as an "update", never mind that there seems to be an MVS/AES toggle for every single version of every single game.
What do you mean the AES is not a home console? Other than it not being exactly affordable...
_Zaphod_
Post by _Zaphod_ »
Here is how the Brocken thing works.
On World Heroes games that had this feature, (which was most of them on location) any knockdown using a string of light attacks by Brocken was an instant KO (and would royally piss off any human player you ever did it to). It did make him the easiest character to beat the game with by far.
That said, he was not the only character that had a death combo. The other characters that could do it involved sliding and dizzys.
https://PrivateLadyEscorts.com - Where To Local Private Lady - No Selfie - Anonymous Adult Dating - Anonymous Dating Chat
GJTMarper
Post by GJTMarper »
_Zaphod_ wrote:That said, he was not the only character that had a death combo. The other characters that could do it involved sliding and dizzys.
So should there be a special rule with this game banning use of any character with an instant-KO combo (or at least using Brocken)? It doesn't seem fair to compare scores by players using a character with a (probably caused by a bug in the program) instant-KO combo vs. players that use a character that doesn't have an instant-KO combo.
Before making a special rule, can someone post there an inp showing what you're talking about ?
I've watched 1st place on wh1, I don't see any "instant ko"
Uh? Characters in fighting games are never created equal, some are just naturally better. Seems silly to ban certain characters, especially when this is not the only fighting game that has characters that can outright kill with one combo (or a dizzy leading into another combo). And that might not even be the key to getting the highest possible score, so...
Special rules is not necessary for this game. Brocken not have an immediate K.O. with 1 hit, but only big damage with multiple low kick. I don't know other characters with big damage however. But I know this: for top score Brocken is not the best character, and is possible a better score with Rasputin, Janne and Muscle Power.
