Which means you should be uploading your scores to viostormeb (game list clearly states "version EAB"). And if you're using MAME 0.150 or later, you should be recording viostormeb, too.PG3 wrote:- 0.150: RanaElia added Violent Storm (ver EAC). Renamed (viostorm) to (viostormeb).wolfman24 wrote:if there is a problem with the game or you are having problems recording you can use .106
http://www.progettoemma.net/gioco.php?game=viostorm
T14 Rules
Moderator: giro-X
Re: T14 Rules
Re: T14 Rules
oops that was my bad it was suppose to be EAC the parent rom. sorry about the confusion and thanks for the catch mahlemiutmahlemiut wrote:Which means you should be uploading your scores to viostormeb (game list clearly states "version EAB"). And if you're using MAME 0.150 or later, you should be recording viostormeb, too.PG3 wrote:- 0.150: RanaElia added Violent Storm (ver EAC). Renamed (viostorm) to (viostormeb).wolfman24 wrote:if there is a problem with the game or you are having problems recording you can use .106
Re: T14 Rules
In that case, then, you can't use 0.106, since version EAC doesn't exist in 0.106.wolfman24 wrote:oops that was my bad it was suppose to be EAC the parent rom. sorry about the confusion and thanks for the catch mahlemiut
Re: T14 Rules
You need to provide the game shortname to the commandline. Providing nothing tells MAME there is no selected driver, and will use the built-in menu to select a driver.
You might also want to set a value for inpview in mame.ini, although it should revert to 0 (meaning disabled) not an empty string.
Re: T14 Rules
Desyncs for me at 1,339,400wolfman24 wrote:Is anyone able to playback PG3 violent storm score? It desync for me at the 2nd boss. Is there any playback problems with the game in the past?
Re: T14 Rules
Barry is right.mahlemiut wrote:You need to provide the game shortname to the commandline. Providing nothing tells MAME there is no selected driver, and will use the built-in menu to select a driver.
Try :
mamearcade viostorm -record viostorm.inp
and
mamearcade viostorm -pb viostorm.inp
Re: T14 Rules
So tourney is on the new "viostorm" (EAC), right ?wolfman24 wrote: oops that was my bad it was suppose to be EAC the parent rom. sorry about the confusion and thanks for the catch mahlemiut
EDIT :
I see you've corrected "EAB" to "EAC" in the game list, so forget my question
- CrazyKongFan
- MARP Knight
Re: T14 Rules
Is it too late to register now that it's started?
- simpsons99
Re: T14 Rules
I had no clue this had started .. I never saw a sign up or anything .
Arcade Game Scores
Arcade Game Scores
Re: T14 Rules
can still sign up now just start submitting scores and I will add you to the scoreboardCrazyKongFan wrote:Is it too late to register now that it's started?
Re: T14 Rules
yeah that was my bad I didn't post the signup intil about the 25th you can still join in thoughsimpsons99 wrote:I had no clue this had started .. I never saw a sign up or anything .
- simpsons99
Re: T14 Rules
confused where is this sign up?
Arcade Game Scores
Arcade Game Scores
- simpsons99
Re: T14 Rules
found it
I have Zupapa score already .. Great choice though
2nd
special rules Zupapa!
(zupapa) simpsons99 (@) 12 Aug 11
23:19:56 4,985,200 (edit) wolf106
get MAME
2nd
get MAME
Arcade Game Scores
Arcade Game Scores
Re: T14 Rules
you can just start submitted scores and I will add them to the leaderboardsimpsons99 wrote:confused where is this sign up?
