Recent Verisons of Mame Recording problems
simpsons99
Re: Recent Verisons of Mame Recording problems
Post by simpsons99 »
after I put dkong3 for both of them? Should It Load the game?
Nothing happens ..
Arcade Game Scores
DaLar
Post by DaLar »
This 'improved' Record.bat file is great :) (I added -video ddraw and -window)
To make it foolproof, maybe give user a written feedback if the game/rom is not complete..: I had an incorrect rom for dkong3 and the new Record.bat will just blink black and close quickly //"What happend?"// c",)
DaLar wrote:This 'improved' Record.bat file is great :) (I added -video ddraw and -window)
Another reason why you should run it from a command prompt, otherwise you miss out what can be rather useful information.
simpsons99
Can you see I am trying to figure it out .
Arcade Game Scores
simpsons99
I think I figured it out .. How do I play back Inps now? I did a test game of Raiden 2
Arcade Game Scores
playback.bat works exactly the same as record.bat does (expect that it plays back the INP, instead of recording one obviously :))
DaLar
Post by DaLar »
I changed of few words in the 'improved' Record.bat and re-named it PlaybackPrompt.bat :)
playback prompt.zip
(645 Bytes) Downloaded 238 times
simpsons99
DaLar wrote:I changed of few words in the 'improved' Record.bat and re-named it PlaybackPrompt.bat :)
yep that worked ty!
Arcade Game Scores
Good to see/hear. :)
You could add a new line at the bottom of the file which reads:
pause
That will stop the black window closing so you can see the information from MAME.
Oh, I also discovered that CTRL+C doesn't stop the batch file like it says it should. Mea culpa. :(
