T13 - Round 4 - batcir
Moderator: giro-X
Re: T13 - Round 4 - batcir
CPS-2 games have never had issues before. I'd just make sure they aren't using default NVRAM.
giro-X
Post by giro-X »
Ladies and gentlemen!
(I'd say... more gentlemen... :D )
I've solved up to now every trouble with past Battle Circuit INP of yours.
Get a refresh on the ranking of this game only 8)
Round 4 - batcir
#  Name                   Score    TP Day 7    TP Day 28    Status
1  SFCHAMPION           1681400          12          100    OK
2  mahlemiut            1480600          10           88    OK *claimed 1460800*
3  Mr. Kelly R. Flewin   655300           8           38    OK
4  Krj                   626200           7           37    OK *finally :)*
5  AGODZILLA@AIVA        537000           6           31    OK
6  xelnia                427000           5           25    OK
7  Fordy                 422000           4           25    OK
8  kernzy                212500           3           12    OK
simpsons99
Post by simpsons99 »
what has changed on this rom set since wolf 142 .. I can not get it to work with 152 or others but wolf106 and wolf142 works fine?
Arcade Game Scores
giro-X wrote:Important notice
The romset name is: batcir
BUT
To make the game work properly, you need also the romset: qsound
simpsons99
TY
BUT
Arcade Game Scores
Watched SFCHAMPION's INP. Definitely requires default NVRAM. MARP general rules require no NVRAM to be present.
giro-X
Post by giro-X »
mahlemiut wrote:Watched SFCHAMPION's INP. Definitely requires default NVRAM. MARP general rules require no NVRAM to be present.
Re-checked, thanks. Wolf B. has the truth.
(The score was also confirmed in Marp, whoops.)
Starting to get the groove back... ;)
br_t13-batcir_2218700.zip
Stage 6, lost to Zipang. 2,218,700. T13, SDL, 64-bit
(968.39 KiB) Downloaded 1025 times
Shoulda used another Death Blow... #-o
Have to post a link - just crept past the 1MB limit.
http://mahlemiut.marpirc.net/br_t13-batcir_2681400.7z
2,618,400. Stage 7. SDL, 64-bit
Slight improvement. Lost to Pluto. I hate Pluto. ;)
http://mahlemiut.marpirc.net/br_t13-batcir_2808300.zip
2,808,300. Stage 7 boss. Still needs work. T13, SDL, 64-bit
giro-X
Post by giro-X »
For saulonpb: I don't know if this is the reason why Battle Circuit is not working to you on wolf 0.152, but I repeat it, in the case you may have not noticed.
BUT
Since we are trying to limit as much as possible the use by players of the 0.106 version of WolfMAME,
:arrow: troubles in running the application with the proper game are not a valid reason to switch version, because it can always be fixed so our aim would be to be able to run it (it would rather be troublesome for some users to run "ancient" versions of MAME, not the newest).
:arrow: when then the application is running properly, if the recording speed is too slow, you are permitted to use older version, but we should see first an example of "bad" recording with speed troubles.
simpsons99
He is always trying to make his own rules
giro-X wrote:For saulonpb: I don't know if this is the reason why Battle Circuit is not working to you on wolf 0.152, but I repeat it, in the case you may have not noticed.
BUT
Arcade Game Scores
Just a bit of fun, I enjoy using Yellow Iris, but find it a bit more difficult. So this is a bit more sucky, but was fun. :)
http://mahlemiut.marpirc.net/br_batcir_iris_2m.zip
Better score... slowly getting there...
http://mahlemiut.marpirc.net/br_t13-batcir_3002600.zip
3,002,600. Stage 7. Still hate Pluto. And Asura. :/ T13, SDL, 64-bit
Marginal improvement... Need to stop the stupid deaths.
http://mahlemiut.marpirc.net/br_t13-batcir_3088200.zip
3,088,200. Stage 7. Rank S x3.
