Wolfmame 150, Not workig
Hello Friends, wolfmame150 is not working on my Laptop, When i try to play the game or record the game then black screen appears, no any error message. when i press Alt-Tab button then computer shows it running. And with ESC it goes back to the wolfmame150 folder where i have opened the batch file. Can any one guide me to solve it..?? Thanks.
Re: Wolfmame 150, Not workig
Do you have windows8?
During black screen is there any sound?
Try with the option -window (I've sent a message to you to do that in my batch file): if it's only a fullscreen mode problem this should solve for the moment, then we could find the best graphic mode to run emulation.
Sounds like it could be the issue with D3D and Intel integrated video chipsets. Try -video ddraw.
No RAX, I am using Windows7, and i am hearing the Sound during black screen.
Yes i put (-window) in Play.bat file. But this time no whole screen black, only vertically black screen appears in front of CMD window.
@mahlemiut: where i can replace the D3D with ddraw?? Where is .ini file??
Sorry, because i am not familiar to use these newer versions of wolfmame, even Wolfmame148 is working perfect on my Laptop. (RoughRanger). and i did not try Wolfmame149 either.
Edit with notepad my play.bat file
the third row is:
Change it to:
the third row is:
set MAMEOPT=Code: Select all
set MAMEOPT=-video ddrawRe: Wolfmame 150, Not workig
mame.ini is located in the same folder as mame.exe
If it doesn't exist, then run 'mame -cc' (without quotes), and it'll create one for you.
Thanks RAX, It's working now. (y)
Thanks mahlemiut.
Thanks mahlemiut.
- ballas
- MARP Knight
Does anyone know where I can find a list of NON WORKING ROMS in MAME 0.150 or 0.151?
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Koos van Dyk
Johannesburg
SOUTH AFRICA
In 0.151, out of 29,610 drivers, 20,004 are marked as not working. A large number of those are likely to have mechanical parts to them, and has such, are likely to never be "working".
- ballas
- MARP Knight
Thanks, what I am trying to get at is there ever say games that worked in wolf 0.106 that later on does not work on let's say version 0.150 or are there only games added from one version to another. I know you need teh proper roms for a certain version of MAME.
KVD
Koos van Dyk
Johannesburg
SOUTH AFRICA
Koos van Dyk
Johannesburg
SOUTH AFRICA
