I've found three Chelnov INPs that should be moved to other romset of the game. They are the following:
1) GameGuru - 96,000 points - http://replay.marpirc.net/inp/9/4/9/db_ ... _m37b3.zip
The INP is currently in Chelnov - Atomic Runner (Japan) [chelnovj], but it was not played using that version of the game. The INP should be moved to Chelnov - Atomic Runner (US) [chelnovu]. This player already has got an INP in chelnovu (95,500 points), but it is a lower score and so this last INP should be deleted.
2) HoLeCorna - 273,550 points - http://replay.marpirc.net/inp/a/5/6/hlc ... m37b15.zip
The INP is currently in Chelnov - Atomic Runner (World) [chelnov], but it was not played using that version of the game (World version was introduced in MAME 0.53). The INP should be moved to Chelnov - Atomic Runner (US) [chelnovu].
3) Olivier Millardet - 93,150 points - http://replay.marpirc.net/inp/c/a/d/om_ ... _win81.zip
It's the same case as 2).
Regards!
Chelnov INPs to be moved
Re: Chelnov INPs to be moved
All fixed.
I let you (re)confirm
- il_kornutazzo
- Button Slapper
As HoLeCorna was my previous nick on marp (before losing the password and being forced to make a new account), I wanna say this: when I played this game with my old version of mame (m37b15), I could see only 2 romsets for it, chelnov and chelnovj, but the second one didn't work for me, so I used only the first one. Checking that romset it seems to be true that later it has been renamed "chelnovu", but I can't understand how now I have 1 inp submitted under "chelnovu" (the one just moved) and another one (score 270,950) still submitted under "chelnov", if I always used the same romset and mame version. Or am I wrong?
Because I didn't check if you had an hidden inp behind the first one.
Now fixed
Now fixed
Now we have all replays confirmed and within the correct romset. Thank you!
If you want, you can download the 2 inps made under this nick (chelnovu/niyanpai) and reupload under your new nickil_kornutazzo wrote:HoLeCorna was my previous nick on marp
