I've been testing out some new strategies on Pac-man and ran into some anomalies. Once in a while the game will briefly freeze and some times skip ahead. I assume that this may be because of processes running in the background.(Though I have nothing running that I can tell).
A bigger problem is in the game play itself. If I run a pattern about ten percent of the time something different will happen. And I'm talking about a pattern that works as good as 100 percent of the time on the arcade platform. But in MAME the relative distance of Pac-man from the monsters at any given point in the maze just will not remain consistent from one identical maze to the next. (This of course causes the pattern to break).
Does anyone know the reason for this? Is this a MAME bug?
Thanks a lot.
Darren
Inconsistent Pac-man Patterns in MAME
Re: Inconsistent Pac-man Patterns in MAME
the first point is probably machine related and not emulation, keep the F11 view open and you should be able to count frames when emulation is running and see the counter stop if the machine is taking over and doing something else while the emulation pauses.
I figured as much. But it's the pattern breaks that are the big problem.Chad wrote:the first point is probably machine related and not emulation, keep the F11 view open and you should be able to count frames when emulation is running and see the counter stop if the machine is taking over and doing something else while the emulation pauses.
I know it's not my control panel because it is the same control panel taken off of my machine and connected to a controller.
Thanks.
Darren
If there's a pattern break then you haven't followed the pattern pixel-perfectly by not turning into corners before you reach them etc. Or maybe your machine decided to 'freeze' for 1 or 2 frames while you made a turn which would break the pattern, this is what happened to me in my split screen attempt which is on MARP.
You could also frame step with shift-P through recordings where the pattern breaks and investigate more closely. MAME used to be able to display the frame-count which would help while stepping through but I can't find this feature any more.
That's probably the reason...because other players can duplicate pacman patterns.LordGaz wrote:If there's a pattern break then you haven't followed the pattern pixel-perfectly by not turning into corners before you reach them etc. Or maybe your machine decided to 'freeze' for 1 or 2 frames while you made a turn which would break the pattern, this is what happened to me in my split screen attempt which is on MARP.
Of course if you still think it's mame, you can try some other mame versions known to work with pac-terns.
Hard to imagine that the relative speed of ghosts would be different to the speed of pacman's since both are defined by mame and roms used, right?
I'd rather think that if emulation is off then both the monsters and pac would move more slowly or faster than the original...but still same speed relative to each other.
I had a thought that it could also be Darren's joystick interface hack(ps2/usb etc) having lag in execution compared to original. Having the original stick doesn't mean that the circuitry where the stick is hacked to has identical timing to arcade hard/software.
The feel and accuracy of my Star Wars yoke hack is far from arcade because of USB/driver/Windows problems.
But yeah, the freezing effect can certainly screw your timing. I sometimes have the same problem when antivirus program kicks in downloading updates. Or during HD operations such as writing the inp during gameplay.
