Triple punch leeching
dan
Post by dan »
Seems to be able to leech easily because time-count being over doesn't be a mistake.
triplep_wolf104.zip
easy leeching?
(67.94 KiB) Downloaded 219 times
We could say that any leeching inp is not allowed.
or...
Add special rule that you must not exceed time-counter...or inp will disqualified.
What do you think?
dan
Post by dan »
I want to refer the following.
viewtopic.php?t=12375
I think that it looks like the case of round-up well.
In both cases, I think that it can earn it without the limitation of time.
However, it is easy or is difficult to differ.
I am hoping to add a special rule to both.
round-up and triple punchi.
dan wrote: I am hoping to add a special rule to both.
Dan, do you mean a rule as:
"You must not exceed time-counter...or inp will disqualified"?
Des, maybe you know something about round-up?
dan
Post by dan »
I think that you must not exceed time-counter...AND follow inp will disqualified.
http://marp.retrogames.com/index.cgi?mo ... per_game=3
The TJT wrote:Des, maybe you know something about round-up?
Wait a while, I must back to this game.
EDIT
Round-up.
As I said before I accept each rule for this game. But remember, infinite leeching is very hard to do here. Enemies are faster with every second. Doesn't depend it is on first or next stage. If you show me replay with score 500k on one life on one stage then I can say that yes, infinite leeching MAYBE is possible, made 2 millions and then I say, yes infinite leeching IS possible.
And yes, otherwise every can beat my score from 1st on first stage only. My best score using 1 life on stage 1 if I good remember is about 120-150k.
If we want interesting replays we can made special rule about finishing stage before time is 400.
Second option is bonus points for every finished stage.
And remember, for this game special rule isn't required. I can made identical high scores using leeching and without leeching.
If we want to make betters scores than on TG I for not add special rules. I can reach the same stage using 1 life or all life. I use all life to maximize score on stage 1 and next go throught next stages without leeching.
Maybe better don't use special rules at this time for this game. If somebody made 2mln or more using leeching we will back to this problem.
Triple-Punch
I watched dan's triple-punch replay, I see you died because two enemies go to you from two different sides. Then here is hard to say about infnite leeching too. Show me inp with 500k and I say yes, inifinite leeching is possible:P
And as for round-up if we want interesting replays special rule about timer can be added.
Bonus for every finished stage is useless in this game beacuse I see that enemies are very slow here.
As for roundup we can wait until somebode submit very very high sore using leeching and next back to this topic.
dan
Post by dan »
I see, Des.
In Japan, the score of the game becomes not significant at all exactly at that time if it is theoretical and possible to execute even if it is not possible to execute it infinitely.
