One of this game tips:
A disadvantageous item like the poison mushroom doesn't appear at all if you were inserting surplus credits.
Surplus credits of Saboten Bombers is OK?
Sorry,I was not able to explain well.
It is against multiple credit rules of MARP.
But,how about play with only one of multiple credits?
I did not want to say it is unfair but I wanted to confirm whether there is no problem.
*1play of 1credit
*only 1play of multiple credit.(Credits of the remainder is not used)
The latter is a little advantageous to the extent that a disadvantageous item doesn't be put though it is the same one play.
oga and GSY are putting 2credits first.
*1play of 1credit
In that case, is not credit consumed?Zhorik wrote:I would think not allowed.
Xybots does something similar where if you enter any number of credits at the initial screen then start the one player game, you get the 25 coins + however many credits are in the game at that time.
eg. 25 coins for 1st level warp + 10 credits = 35 coins at first shop.
I want to know the case where the credit of the remainder is not consumed to
the end at all.
No it does not consume other credits.dan wrote:In that case, is not credit consumed?Zhorik wrote:I would think not allowed.
the end at all.
Actually you get the extra coin any time you insert a credit; you don't have to use the warp or insert the credit before you start the game. You can only have a maximum of 25 credits stored on the machine at any time.
For example, enter 25 credits, press one player start. It consumes 1 credit, but you start with 25 coins instead of the normal 1. The rule should be, insert one credit, you start with one coin. It should then be illegal to insert any more credits at any time during game play, because if you do, you get extra coins during the current game (but it doesn't consume the credit you inserted).
I'm not sure if I understand. Maybe you mean: "Can you draw a line between more easy and too easy?"dan wrote:Can you mark off a boundary to becoming easiness excessive, and a little
becoming easiness?
Well, I don't know the right answer.
But my current view is that extra credits would be OK at this game, because 1 credit rule was implemented for other reasons.
Exactly, it is what I wanted to say.The TJT wrote: I'm not sure if I understand. Maybe you mean: "Can you draw a line between more easy and too easy?"
