trally scoring
trally scoring
I propose a time basis scoring for this one :
each race completed = 100000 - time in centiseconds
For example :
Hookman would have 500000-7035-7420-6531-7604-9547 = 461863
Massimo (if inp works for one of you) would have 600000 - his times
Opinions ?
So scoring for game would be:
(number of races completed *100 000) - (time in seconds * 100)
Sounds ok to me. Others?
No need to think this for eternity, no reason to reject this scoring...
So I think it's safe for you Phil to edit special rules for the game.
...And while you are a at it, why not make rules also for...
http://marp.retrogames.com/index.cgi?mo ... radr,radu)
(or is right link: http://marp.retrogames.com/index.cgi?mo ... ,radru-c4)
viewtopic.php?t=12035
OK? :)
Ok ; you will have to patient till next monday, I'm away from home with twins for 3 or 4 days.
But I will update special rules and playback/edit all inputs then
By the way, Massimo's trally input ? need a third to zero, or someone can play it back ?
Sorry can't help with playback...don't have win53. (tried with 55, no success).
Anyways, TIA a bunch...and have a relaxing weekend :)
The TJT wrote:don't have win53
http://mame.joymonkey.com/mame32/
Ouf !! Lot of work (many inputs) but it's done.
Special rules for trally (and trally-a) edited, all inputs playbacked and scores adjusted to new rules (all inputs except Abbe's ; see playbackability section ... anyone lucky with this one ?)
Note that several inputs were made using nvram, some made before the nvram rule was instaured, others (like the first place) after ; I will let Tommi decide what to do on these ones.
I will put this game tomorrow in WCC, so maybe we can let 1 week to Massimo for improvment ; and if he doesn't then zero ?
Phil Lamat wrote:Ouf !! Lot of work (many inputs) but it's done.
Job well done Philippe :D
Would it be propriate to ask editing similar special rules for radr+radru that I mentioned above? :oops:
Since trally inps can be recorded without nvram... you are free to zero recordings with nvram, at will, submitted at 2002 or later.
The TJT wrote:Would it be propriate to ask editing similar special rules for radr+radru
Done
The TJT wrote:Since trally inps can be recorded without nvram... you are free to zero recordings with nvram, at will, submitted at 2002 or later.
Only Massimo was concerned ; inp zeroed (his previous inp playbacks without nvram)
