of course that matters too...but nvram doesn't affect the score from any of the other events. If it did, then you would be hearing about it.QRS wrote:If that is the only reason top players are playing the game I can't help you. I find it hard to belive that the rest of the game doen't matter.
It's the same versus having a standard/required nvram file be used for official scoring also.True, but on a leveled base. Without NVRAM you are 100% sure that all players start from scratch with NO advantages.
QRS, look at it like this. We are both masters of HS to the point we both fail at the 9.60 horse vault(has anyone ever passed this...hmmm) but you are just a tad faster at running than I am.Yes, but that is irrelevant. If you compete in MARP rules you compare your score to MARP, not TG.
...so let's say from all those running type events you can outscore me typically by 5000-10000. That's all we are talking here. I remember my top 5 scores all being within a 5000 range!
Ok, without nvram, you can outscore me by 5-10+k. Ok, let's say I have mastered the pole plants in the pole vault a tad better than you have. With nvram, I can potentially outscore you by 8k, 16k, 24k, etc. Without any nvram use, I can't outscore you at all as those would all be good for "records" so no mole points awarded.
Without the nvram, you have totally taken away an aspect of playing and scoring at the game...but without affecting the actual gameplay at all.
For other games BBH and others have given as precedents, it's not the same cuz in each case the gameplay is somewhat changed also. ie. can warp or use a different character or experience gained from previous plays etc.
As stated above, half the point is to emulate the arcade games...
HS Arcade games--set to reset the records on reset...
Any player going for a top score would certainly play the game at least a couple times to get at least all 5.93s on the pole vault records before even thinking about playing serious games.
...cuz to do differently means they have no chance of beating the top score on that machine...or WR attempt etc.
Each and every gamer gets to do this on each arcade machine. So you could allow this for MAME...which means each makes their own nvram file...or you can have a standard nvram to use to at least keep things level there.
As noted, using cheats like autofire etc. you can set heights higher than what others not cheating could set...thus potentially gaining an advantage from cheating in setting the heights for the nvram.
I and likely all the HS players can totally understand wanting that to NOT happen.
However, not using any nvram file does give an advantage...to those that are slightly faster runners....but not so great at the pole vault.
Of course not...but he should state his argument in a forum post to inform all of us so then we each can decide.On the other hand, if only one person really are good at the game, should only he decide about that game?
After those discussions, even an average HS player can easily make a judgement decision in regards to nvram without thinking of their own potential benefit.
...make a purely objective decision in the fairness of gaming.
Hardly...BBH clearly stated this above. He doesn't want that can of worms opened.Also, none of the editors are "scared" of similar requests.
BBH didn't validate his decision based on HS...but based on other games...not wanting to open a can of worms for this potentially becoming an issue for other games.
IMHO that invalidates his vote. I wonder how many other editors thought similarly.
