timber
timber
http://marp.retrogames.com/inp/7/a/f/ki ... mame62.zip
-nosound causes error
deleted nvram
the 1million game i watched to 100,000.
sampras73
Post by sampras73 »
Is the same problem of Wacho....
viewtopic.php?t=11502
I've no NVRAM file of timber in my Alphamame directory, I used
only the option -noafs...
I made another recording with Timber, on my computer is ok...
but also the 400k recording...
Next time I try to record with the wolfmame...
Thank you
Bye Sampras
sampras73 wrote:Is the same problem of Wacho....
Thank you
Bye Sampras
Anybody have any idea what the problem is here?
I think he lost a second place on Wacko because of this.
this could be a sound frequency thing, but i can't seem to match it, zeroed for now since three can't play it back. maybe report your freqs. i don't think fs0 is required in this game, but i bet nosound might be.
Chad wrote:this could be a sound frequency thing, but i can't seem to match it, zeroed for now since three can't play it back. maybe report your freqs. i don't think fs0 is required in this game, but i bet nosound might be.
If he's still using the same config he was when the Wacko problem came up, it's 44100.
I tried using his config, as I did back then, to no avail.
Worth a shot trying with -nosound, and with WolfMAME .83.
The .63 bug shouldn't prevent me from playing it back regardless of which set he falls into.
His problem seems to be unusual.
Timber is similar to Tapper....which is fairly picky for playback. You need the same frequency setting and frameskip setting for playback to possibly work.
...even then I have had a few times when my own replay goes out of sync on playback.
