Woflamame 0.83 Src
DOCyoyo_49
Woflamame 0.83 Src
Post by DOCyoyo_49 »
I seek the source of wolfmame 32 version 0.83, are it available in download? does somebody have a bond?
yes, the source patch is on the wolfmame site.
wolfmame.marpirc.net
DOCyoyo_49
I found that the source of alphamame 0.63 A this address: http://wolfmame.marpirc.net/
I do not see of it the source of wolfmame 0.83
LordGaz
Post by LordGaz »
Why do you want the source?
0.77 source here - http://wolfmame.marpirc.net/wolf077patch.diff
A bit out of date, but should still playback inps if applied to MAME Plus 0.83.
I'll upload a more up to date version eventually (I'm just lazy :))
DOCyoyo_49
I would like the source of version .83 to be able to compile my bluid mame and to have the function for the recording...
Version .77 and too day before, and its will not be to me utille ....
that answer sort of implied... i think what gaz was asking is what functionality are you adding that can't be received from getting the standard executable?
DOCyoyo_49
Chad I did not understand your post (I am French :? ) ,
I want to know if the source of wolfmame 0.83 are available so that I can compile my bluid,
thank you !!
Blost
Post by Blost »
En fait WolfMAME c'est une modif de MAME/MAME32 Plus!.
Si tu veux faire ton propre build il te faut le source de MAME, le diff de MAME Plus! et celui de WolfMAME.
MAME Plus! c'est là :
http://mame.emu-zone.org/
DOCyoyo_49
Sa a l'air bien chiant avec tous c'est diff, deja que pour compiler mon mame32 "classique" je galere alors la :( !!!
Si tu a un lien ver un tuto qi explique comment compiler avec les diff je suis preneur !
Merci d'avance , aplus
