Sawys' Scramble Spirits recording
I do have one more question... just how long did it take you to make this recording?
Time
Missions completed in 35 minutes from the beginning till the game over.
But if this is bad for me, my problem is that i have no way to know if i am under the real speed with Wolfmame.
Maybe there is a bug with the configuration in my system.
Ok, that game should have only taken 15 minutes by my calculations. There's something mightily strange going on if 100% speed is reported, when it so obviously isn't running at 100%.
Are there any unusual programs that you have running in the background that may cause this... antivirus programs can sometimes cause problems.
i viewed the ambush techfri
the french touch ?
where is the joan of arc spirit ?
you can do better
coach
First : I have no antivirus, only msn messenger closed, image transfer and In Cd. I don't know what happens.
Second : I post this score on my 2nd game. I discover this game and know that 2nd place is easier to reach than 1st but I will later play better.
You know I just have a baby on 11th april 2004 and I have no much time to play. I try to make it but it's hard now !
Plus
I wanted to add that as i said when you choose the olympic leader board, now , the most important is the rank and not the score and for me it's not important if I am 2nd or 1st.
If the score to beat is easy in the 2nd place, i make it and later i will be back when someone beats me.
The modification of the leaderboard changed my way of thinking and playing with MARP.
Re: 2 answers
sawys wrote:First : I have no antivirus, only msn messenger closed, image transfer and In Cd. I don't know what happens.
So maybe you have virus then :wink:
Buttermaker
Post by Buttermaker »
Run sspirits in a window, press F11, press alt+print to take a screenshot, paste it in some graphic program (e.g. MS Paint) and post that screenshot here.
Screenshot
Here it is
Buttermaker
Now run the command line version of WolfMAME (mamep.exe) like this:
mamep.exe sspirits -ftr 5000 -nothrottle -noafs
When it's finished take a screenshot of your command prompt window and post it.
Re: 2 answers
sawys wrote:You know I just have a baby on 11th april 2004 and I have no much time to play. I try to make it but it's hard now !
Funny ; my twins are born 11th april 2003
1 - Here is the screenshot if this is ok.
2 - Phil Lamat, are you french because I saw your highscore in http://www.jvrm.net. You are good to Mahjong !!
Re: 2 answers
sawys wrote: 2 - Phil Lamat, are you french because I saw your highscore in http://www.jvrm.net. You are good to Mahjong !!
Français jusqu'au bout des ongles, oui ;
j'ai par contre peu de scores sur Jvrm car je te laisse découvrir la vie avec un enfant, et tu comprendras vite que s'il y en a deux ...
Buttermaker
Re: 2 answers
sawys wrote:1 - Here is the screenshot if this is ok.
Not exactly. I said mamep.exe, not mame32p.exe. In your "exécuter" window type cmd and hit return. That is the command prompt. Run mamep.exe from there and take a screenshot of the command prompt window after MAME finishes.
The good screenshot
Here it is again !
