I'm not so happy to write about this, but I can not watch someone play unfair and do nothing about it.
I don't know preloads real name, and maybe not wise to tell where he is busted. So easy to change email and marp prefix.But I tell anyway
he has been busted by programs of Chad and Barry and some details I notice simply by watching hes inps.
The big fuss here is not because he would have made some extraordinary scores at TF or other games. This is simply a matter of eliminating the cheats. Yes, I have to admit though, that I do not want to better my scores because of someone simply cheating.
I'm somewhat against multiple button mapping(and I admit I use 2 buttons for running at TF, but joystick at High Jump. If you really want I can explain why), but that is not the issue in this thread.
First I looked at hes Trackfld inp, for fun. I find some not so obvious strange things there. Then I start looking hes other similar inps.
First preload makes an inp at fieldday which is questioned for autof, then he makes equally looking inp, which is nearly busted but not quite. Maybe he slows down hes autofire a bit. Great, he has found the acceptable cheat value.
HARD EVIDENCE:
The question is: How does he make new, valid, inp with same controls that he used before????????, maybe he just runs slower with hes joystick(irony)
If cheat once, trust is lost.
Something to think about:
SOFT EVIDENCE:
He is not so fast at TF 100m, "only" about 8,20. But at 110m he is at EVERY inp really MUCH faster compared to hes speed at 100m. That can be just statistical differ, but as he says he uses all the time same controls every event every game -such variation of speed should be impropable.
Yet at some games/some events hes speeds stay same beyond my comprehension.
I suspect he uses cheat only sometimes, at some events. Some events look just like they should look when played fair.
Then again, logic fails: why not cheat all events?
VERY HARD EVIDENCE:
T&F High Jump: Sometimes hes jumps look normal, but sometimes hes jumps just rise much higher-higher than possible with buttons, or joystick.
Why some jumps look like normal joystick play(with bad timing btw), and some look like I've not seen before(except rlh inps)?
AT HYPROLYB HE JUMPS 2,52m, WHICH IS SURELY FAIR EVIDENCE OF CHEAT, IT IS NOT POSSIBLE. As I remember correctly, he had some margin at that height too.
2.50 is possible with joystick, have even heard about 2,51 with very sensitive joystick(MKM), but he runs 100m much much much faster compared to preload. With preload speeds, no way. I have tried 2,51 several times with Hotrod +infinite tries cheat, can get "near" but never over.
If I would team up with my friend, who can do 6-fingers too, we could get same kind of heights(2,52). But that would be 6fingers at one, and 6 on another button...so called 12 finger technique- which would exceed the amount of fingers for average player
That would not be noticed as autofire surely. Speed of button presses would be alarmingly high though.
Then there are some "over the top" speeds at fieldday/undoukai, as I see.
Full speed at "soft ball" easy to spot.
How can anyone have EXACTLY same speed every high jump of 88games and konami88????!!!!! Allways 2 blocks from max. Otherwise they look pretty ok.
BTW, hes speeds are lesser than mine at these 2games, so I should be able to jump 2,52 at highjump too, or more. Which proves my point.
Maybe he has some kind of reasoning for cheating at high jump events.
The question is:
He clearly cheats at some games/events. How we know if other are valid? What will we do about it? I woul suggest 2 year ban from marp because of doping!
Or just delete all hes sports inps. Yes, all.
TJT
7,47
Nobody ever admits they cheat here.
