Vaz (Er Commissianarobeoijdfoif Monnezza) audit
Q.T.Quazar
Post by Q.T.Quazar »
the following do not play back/desynch/have a bad score with advertised settings--as tested by TWO confirmers [QCN,CEH]. consider this two strikes against the following submissions:
win36 cycle
berabohm
http://marp.retrogames.com/inp/8/0/c/va ... _win36.zip
win37b5 cycle
brutforc
http://marp.retrogames.com/inp/3/0/3/va ... in37b5.zip
calibr50
http://marp.retrogames.com/inp/3/e/d/va ... in37b5.zip
cameltrj-beg,exp,spc
http://marp.retrogames.com/inp/6/2/a/va ... in37b5.zip
http://marp.retrogames.com/inp/1/f/1/va ... in37b5.zip
http://marp.retrogames.com/inp/7/3/3/va ... in37b5.zip
grindstm
http://marp.retrogames.com/inp/f/4/9/va ... in37b5.zip
gwarj
http://marp.retrogames.com/inp/b/d/d/va ... in37b5.zip
majest12
http://marp.retrogames.com/inp/6/a/6/va ... in37b5.zip
vfive
http://marp.retrogames.com/inp/8/f/8/va ... in37b5.zip
insector
http://marp.retrogames.com/inp/e/3/4/va ... in37b5.zip
rompers
http://marp.retrogames.com/inp/f/3/e/va ... in37b5.zip
ssrdruda
http://marp.retrogames.com/inp/f/8/6/va ... in37b5.zip
ssriders
http://marp.retrogames.com/inp/e/8/7/va ... in37b5.zip
stratgys
http://marp.retrogames.com/inp/4/0/4/va ... in37b5.zip
two confirmers ends at this point. the following are bad for one confirmer: [QCN].
m34b7 cycle
willowje
http://marp.retrogames.com/inp/7/d/d/va ... _m34b7.zip
nemesis
http://marp.retrogames.com/inp/1/e/3/va ... _m34b7.zip
m35b2 cycle
silkwrm2-heli
http://marp.retrogames.com/inp/e/8/b/va ... _m35b2.zip
win35b5 cycle
spacebrd
http://marp.retrogames.com/inp/7/1/a/va ... in35b5.zip
spacefbg
http://marp.retrogames.com/inp/d/8/8/va ... in35b5.zip
spacedem
http://marp.retrogames.com/inp/0/8/3/va ... in35b5.zip
m35b8 cycle
seawolf
http://marp.retrogames.com/inp/5/e/f/va ... _m35b8.zip
csilver
http://marp.retrogames.com/inp/2/4/d/va ... _m35b8.zip
inferno
http://marp.retrogames.com/inp/8/7/d/va ... _m35b8.zip
psychos
http://marp.retrogames.com/inp/b/9/d/va ... _m35b8.zip
psychosj
http://marp.retrogames.com/inp/e/9/9/va ... _m35b8.zip
m35b9 cycle
sindbadm
http://marp.retrogames.com/inp/2/1/7/va ... _m35b9.zip
bermudat
http://marp.retrogames.com/inp/7/b/d/va ... _m35b9.zip
topsecex
http://marp.retrogames.com/inp/6/3/c/va ... _m35b9.zip
m35b10 cycle
senjyo
http://marp.retrogames.com/inp/9/b/4/va ... m35b10.zip
m35b11 cycle
prehislu
http://marp.retrogames.com/inp/a/d/a/va ... m35b11.zip
wiping
http://marp.retrogames.com/inp/d/d/5/va ... m35b11.zip
m35b12 cycle
gondo
http://marp.retrogames.com/inp/c/1/f/va ... m35b12.zip
makyosen
http://marp.retrogames.com/inp/f/e/3/va ... m35b12.zip
m35b13 cycle
skylancr
http://marp.retrogames.com/inp/b/c/2/va ... m35b13.zip
m36b11 cycle
rthun2
http://marp.retrogames.com/inp/f/1/1/va ... m36b11.zip
win37b1 through 4 cycle *NOTE* no mame32.37b1, 2, or 3 was ever released, meaning these were recorded on unofficial versions. they have accordingly been checked with the closest version in the development cycle, mame32v.37b4. if you are checking these and capable, please try with equivalent dos version instead. if they play back, please annotate the description line with whatever version you used. some of these i've checked with multiple versions, but ensuring playback is the responsibility of the recorder.
win37b1 cycle
1941
http://marp.retrogames.com/inp/8/5/3/va ... in37b1.zip
breywood
http://marp.retrogames.com/inp/5/8/f/va ... in37b1.zip
rabiolep
http://marp.retrogames.com/inp/0/b/5/va ... in37b1.zip
pipibibs
http://marp.retrogames.com/inp/6/b/e/va ... in37b1.zip
cawingj
http://marp.retrogames.com/inp/a/0/8/va ... in37b1.zip
gunhohki
http://marp.retrogames.com/inp/c/4/7/va ... in37b1.zip
mysticri
http://marp.retrogames.com/inp/2/c/a/va ... in37b1.zip
splash
http://marp.retrogames.com/inp/c/c/8/va ... in37b1.zip
xmen2pj
http://marp.retrogames.com/inp/a/8/8/va ... in37b1.zip
kbash
http://marp.retrogames.com/inp/d/f/5/va ... in37b1.zip
term2
http://marp.retrogames.com/inp/c/d/8/va ... in37b1.zip
timesold
http://marp.retrogames.com/inp/6/f/f/va ... in37b1.zip
win37b2 cycle
legofair
http://marp.retrogames.com/inp/b/2/c/va ... in37b2.zip
rpunch
http://marp.retrogames.com/inp/1/6/2/va ... in37b2.zip
metafox
http://marp.retrogames.com/inp/7/b/9/va ... in37b2.zip
ssrdrebc
http://marp.retrogames.com/inp/6/4/f/va ... in37b2.zip
mbombrd
http://marp.retrogames.com/inp/a/2/3/va ... in37b2.zip
burningh
http://marp.retrogames.com/inp/9/7/e/va ... in37b2.zip
dinoj
http://marp.retrogames.com/inp/8/6/5/va ... in37b2.zip
dsaberj
http://marp.retrogames.com/inp/0/a/6/va ... in37b2.zip
win37b3 cycle
crimec
http://marp.retrogames.com/inp/b/3/9/va ... in37b3.zip
crimecj
http://marp.retrogames.com/inp/5/5/3/va ... in37b3.zip
crimecu
http://marp.retrogames.com/inp/b/7/e/va ... in37b3.zip
nastar
http://marp.retrogames.com/inp/2/8/0/va ... in37b3.zip
viper
http://marp.retrogames.com/inp/c/d/e/va ... in37b3.zip
polyplay-rw
http://marp.retrogames.com/inp/d/9/5/va ... in37b3.zip
polyplay-cv
http://marp.retrogames.com/inp/0/c/6/va ... in37b3.zip
polyplay-bf
http://marp.retrogames.com/inp/c/e/2/va ... in37b3.zip
polyplay-ce
http://marp.retrogames.com/inp/d/6/9/va ... in37b3.zip
nastarw
http://marp.retrogames.com/inp/d/a/6/va ... in37b3.zip
wsf - score should be 106 (one match played, 6-0 win--i think--please double check)
http://marp.retrogames.com/inp/b/4/0/va ... in37b3.zip
pigout
http://marp.retrogames.com/inp/0/a/3/va ... _win36.zip
rastsag2
http://marp.retrogames.com/inp/a/4/a/va ... in37b3.zip
win37b4 cycle
blazstar
http://marp.retrogames.com/inp/2/7/8/va ... in37b4.zip
doubledr
http://marp.retrogames.com/inp/3/c/c/va ... in37b4.zip
kabukikl
http://marp.retrogames.com/inp/8/e/4/va ... in37b4.zip
mslug
http://marp.retrogames.com/inp/8/7/f/va ... in37b4.zip
sdodgeb
http://marp.retrogames.com/inp/b/7/8/va ... in37b4.zip
cheyenne
http://marp.retrogames.com/inp/e/0/a/va ... in37b4.zip
win37b7 cycle
biomtoy
http://marp.retrogames.com/inp/c/a/c/va ... in37b7.zip
missw96 (also in another thread, failed for skito as well)
http://marp.retrogames.com/inp/7/3/f/va ... in37b7.zip
newfant (also in another thread, failed for skito as well)
http://marp.retrogames.com/inp/4/1/d/va ... in37b7.zip
mahoudai
http://marp.retrogames.com/inp/e/d/7/va ... in37b7.zip
pollux
http://marp.retrogames.com/inp/2/7/3/va ... _m37b7.zip
win37b8 cycle
ddonpchj
http://marp.retrogames.com/inp/c/9/6/va ... in37b7.zip
dfeveron
http://marp.retrogames.com/inp/4/6/9/va ... in37b8.zip
dfeveron-ta
http://marp.retrogames.com/inp/8/4/c/va ... in37b8.zip
espradeo
http://marp.retrogames.com/inp/a/a/8/va ... in37b8.zip
win37b9 cycle
aburner2
http://marp.retrogames.com/inp/6/a/d/va ... in37b9.zip
tfrceacj
http://marp.retrogames.com/inp/4/2/d/va ... in37b9.zip
gunfront
http://marp.retrogames.com/inp/e/1/9/va ... in37b9.zip
metalb
http://marp.retrogames.com/inp/2/b/0/va ... in37b9.zip
tfrceac
http://marp.retrogames.com/inp/b/9/1/va ... in37b9.zip
gpilots
http://marp.retrogames.com/inp/4/6/c/va ... in37b9.zip
yard
http://marp.retrogames.com/inp/1/7/e/va ... in37b9.zip
bankp
http://marp.retrogames.com/inp/8/0/1/va ... in37b9.zip
mslug2
http://marp.retrogames.com/inp/0/4/a/va ... in37b9.zip
rtype
http://marp.retrogames.com/inp/5/1/7/va ... in37b9.zip
the following do not playback due to ROM name/dump changes:
m35b2
sisv
m35b5
contrab
gryzorb
m35b8
lastmisn
lastmss2 (lastmsno)
lomakaj (lomakai)
m35b9
vanvan
vanvanb (vanvank)
m35b11
cabalbl
m35final
rallybik
win36
ncommand
tumblep
win37b3
tshingen
win37b4
eightman
win37b5
sngkace
rodland,-s
rodlandj,-s
win37b7
zingzip
dwj
sonicwi2
tatsujn2
win37b9
tfrceacb
sonicwi3
pbobblen
win37b10
darius2d
daisenpu
the following .inps could not be checked due to my being unable to run their MAME version
bjourney
twinbee
pow
claypign-skt
claypign-trp
devzone
combat
shackled
elecyoyo
elecyoy2
oscar
mysticm
vimana1
fantzone
eswatbl
raiden
silkworm-heli
timscanr
skysoldr
xybots
outzone
chelnovu
prehisle
the following .inps require score changes:
gigandes - (score change to 137800)
http://marp.retrogames.com/inp/0/4/7/va ... in37b9.zip
fshark - (score change to 403650)
http://marp.retrogames.com/inp/9/e/9/va ... in37b9.zip
bigkarnk - (score change to 59550)
http://marp.retrogames.com/inp/d/1/6/va ... in37b9.zip
gunforcu - (score change to 189301)
http://marp.retrogames.com/inp/c/f/b/va ... in37b8.zip
insectx - (score change to 634700)
http://marp.retrogames.com/inp/a/2/6/va ... m36b10.zip
slyspy - (score change to 162900)
http://marp.retrogames.com/inp/c/c/7/va ... mame34.zip
gunforce - (score change to 187301)
http://marp.retrogames.com/inp/6/7/8/va ... in37b8.zip
yamagchi - score change to 20690
http://marp.retrogames.com/inp/f/4/a/va ... in37b1.zip
pang3-nml -score should be 1,004,000
http://marp.retrogames.com/inp/8/5/4/va ... in37b4.zip
the following .inps can be deleted:
samurai - (Sega game--will not playback in this version)
http://marp.retrogames.com/inp/d/c/4/va ... _m35b5.zip
boxingb - (game was severely broken in this version - score should be deleted)
http://marp.retrogames.com/inp/0/9/1/va ... _m35b8.zip
nprinces - (Sega game)
http://marp.retrogames.com/inp/8/8/2/va ... m35b12.zip
kyros - (file does not exist; entry should be deleted)
sspacatc - HAHAHAHAHAHAHA! This is an Old Sega recording in an unofficial version of MAME32 from a cycle where these didn't play back. Good luck.
http://marp.retrogames.com/inp/a/c/6/va ... in37b2.zip
sspaceat - Vaz is the eternal optimist...
http://marp.retrogames.com/inp/d/5/9/va ... in37b2.zip
sstingry - (file does not exist; entry should be deleted)
bombrman - (looks like wrong .inp type submitted. -vs. for 0 points)
http://marp.retrogames.com/inp/a/0/a/va ... in37b8.zip
labyrunr - (game was broken in this version (collision detection))
http://marp.retrogames.com/inp/a/2/0/va ... _win36.zip
the following have failed for three confirmers [QCN, CEH, ANT] and may be deleted:
this audit is complete as of August 16, 2003. last edit was August 17, 2003.
Kale
Post by Kale »
labyrunr is a recording made with a broken version,might be deleted...
BTW,Er Commissario Monnezza(a.k.a. Thomas Milian) was a great B-movie actor here in Italy in the 1970s,just to say what it means...
Q.T.Quazar
thank-you muchly skito.
the list has been edited/updated. there are still a few deletions/score updates to be made on it when you have a chance.
i am adding to the Vaz audit tonight.i have added remarks as to where the two confirmers/one confirmer break is.
diabolik
Post by diabolik »
Kale wrote:BTW,Er Commissario Monnezza(a.k.a. Thomas Milian) was a great B-movie actor here in Italy in the 1970s,just to say what it means...
Sorry, completely OT :arrow:
Yeah, Tomas Milian made some badass movies! :lol: I just love them (and italian "b-movies" in general)! Kale, do you know what happened to him? Is he still acting/alive?
Cicca
Post by Cicca »
I'm almost sure he's still acting....I guess I saw him in a movie recently, but need to squeeze my mind to get out the title....
What I can tell you, and I guess Kale will agree, is that Thomas Milian used to act in those b and trash movies although he's known to be a good actor...and in fact, he's now acting in more "serious" movies and roles...
diabolik
Post by diabolik »
Cool, if he's still acting. He must be over 70 years old by now.. Yeah, I've heard that many great american actors who couldn't get a job in their home country came to Italy to act in those b-movies (those were the days!)... I'm not sure if that's the case with Milian though...
Kale
Post by Kale »
He's actually 71 years old.
http://digilander.libero.it/italiatrash ... ilmogr.htm
His last film is dated 1994,according to this URL.BTW he refused to being interviewed at a local transmission (Stracult) a year ago,I don't know why.
Wasn't Tomas Milian in "Traffic" by Steven Soderbergh ?
Pika163
Post by Pika163 »
Yes, he was in "Traffic", playing the part of General Arturo Salazar. He's also still acting, too, with another movie coming out next year.
http://www.imdb.com/Name?Milian,+Tomas
---J. Michael Bottorff
"The stupidest kinds of people are the ones who put self-quotes in their signature." --Me
Q.T.Quazar
this audit is now completed. confirmers: if Vaz comes up when you are checking an .inp, please check against this list and post the results in this thread.
Abbe
Post by Abbe »
Well, I have tried to go through the 0.36 cycle at least. It looks like quite a few of these games was recorded in another version. Magix wasn't even added until 0.37b3 for example. I tested most of them in 0.37b4 too.
Terraf, terrafu and thndrx2 behave a little wierd. Mame32 seems to stop playing the game back after a few seconds and the watcher regains control. Perhaps a result of playing them back with the wrong version. Anyone have a clue?
I could confirm some of them. It would be nice if the settings I used could be added to the descriptions for future use.
Here are the results of the swedish jury:
(in the order I found them in the original post)
bermudao - resets at 12000-something
smashtv4 - ok with fskp 0 and directsound, no F10, confirmed
smashtv5 - ok with fskp 0, directsound and default nvram, recorded 07 Apr 00, before nvram was banned
smashtv6 - ok with fskp 0 and directsound, no F10, confirmed
1941 - 88300, no matter what settings I use. Tried both 0.36 and 0.37b4
growl - desyncs
growlu - desyncs
captcomj - desyncs
marvland - inserts coin, but never pushes 1p-button, even with default nvram
4dwarrio - desyncs
terraf - never starts game
terrafu - never starts game, looks broken in both 0.36 and 0.37b4
thndrx2 - starts game with default nvram, but the playback stops a few seconds into the game and the watcher regains control
ultraman - 14 000 , desyncs
magix - plays back fine in mame32 0.37b4 with current (0.72) romset. :? Wasn't added until 0.37b3
berabohm - can't find old romset, so I haven't tested this one
apb2 - game never starts
-Abbe
Q.T.Quazar
thanks, Abbe. i've updated the main audit--would be nice if one of the Editors could annotate the appropriate smashtv4,5,6 and magix.inps
i've also listed a number of score changes and deletions at the bottom of the audit.
Abbe
Post by Abbe »
Went through the 37b10 recordings. Could playback all of them. I used the standard mame32 0.37b10 with the following settings:
omegaf - no sound, no f10, fskp 0
ninjawj - directsound, fskp 0, no f10
ninclown - no sound, fskp 0, no f10
omegafs - no sound, fskp 0
amspdwy - directsound, fskp 0, no f10
amspdwya - directsound, fskp 0, no f10
-Abbe
Q.T.Quazar
made the update, Abbe. master audit has been edited, win37b10 .inps removed and i notice skito has done the deletions. thanks guys!
