To clarify...LN2 wrote:This is what I and many other members don't understand. Look at rule 2c in the MARP rules. It suggests that all tricks that are equivalent to cheating(not playing the game under it's intended rules) are not allowed.***PL*** wrote:You don't get it. Everything in gameplay is legal until a vote to ban the technique passes by 2/3.
MARP General Rule 2c says: Cheats are not permitted. (although many powerups are)
The original intent of this rule is to disallow the use of the MAME Cheat Menu and any type of hack into the MAME emulator. It is a general rule and doesn't mention specific games or techniques. There is no suggestion here that tricks and cheating are the same. If anything, it could be inferred that obvious cheats outside of using cheat.dat are unacceptable. (Do I sound like a lawyer? -- well I'm not!)
That said, if someone wants to introduce a trick, the uploader is the only one at risk of ultimately getting his INP DQ'ed. But this could only happen after a vote takes place and the trick is banned as it is not a general cheat covered by Rule 2c.
So if anyone believes a specific technique is suspect, a MARP vote will be necessary to ultimately ban the cheat/trick. This is how it has always worked since the beginning.
