Syvalion - 104 endings?
I've been told that Syvalion (course B) has 104 endings. I've played back Hisa's recording and he got ending no. 048. Does anyone know how to get the others? Thanks.
http://www.vazcomics.org/mamend/ -- MamEnd: when the end is just the beginning...
Re: Syvalion - 104 endings?
Just play it a hell of a lot. It's probably at least partly random.Vaz wrote:I've been told that Syvalion (course B) has 104 endings. I've played back Hisa's recording and he got ending no. 048. Does anyone know how to get the others? Thanks.
- The greatest info supplyer
sorry. I do not know.(my "I do not know" means "random/not defined/no one know about it.")
many endings require continue/die/perfect/wipe out/ or special act.
http://www.interq.or.jp/black/sekkey/sy ... alion.html
has syvalion-ending-complete project. but even he could collect only 40 endings.
and I do not know 104 is right or not. I only know "No one saw 105 or later."
It uses rand seed for selecting the level that you should do at the start,then probably it selects the successive levels by your performance;the ending can be either 1= perfect<-> 105=suck ,or something else(like Hisa said).The best thing is to check different plays and see what they changes between them...
PS:Vaz,ti darò una mano per il tuo sito.Aspetta solo un po' e ti mandero' un e-mail...
Scusa se ti rispondo solo ora, ma non mi ero accorto che avevi scirtto qui (e non mi pare che mi sia arrivata la segnalazione automatica). Aspetto con piacere qualsiasi tuo contributo, ma ora che hai da fare con il MAME Team immagino che sarai molto impegnato...Kale wrote:PS:Vaz,ti darò una mano per il tuo sito.Aspetta solo un po' e ti mandero' un e-mail...
Ho finito Strider 2, tu che sei un grande fan dell'1, che te ne pare?
Mah,non sono "veramente" impegnato ,passo soltanto qualche ora a fissare bugs e magari qualcosa di piu' importante(vedi Block Gal),tutto qui.Vaz wrote:
Per me Strider 2 fa schifo,l'ho gia detto da qualche altra parte nella vecchia msg.E non ha molto in comune con il primo,non a caso i programmatori del primo sono stati "venduti" all'Atlus...
