Removing motion blur for LCDs with MAME
Post by The_Pro » Thu Oct 17, 2013 10:44 pm
This might be old news to some but I haven't seen it mentioned here.
There are some monitors now that are starting to offer 120Hz refresh rates with a feature called lightboost. Without going into too much detail, it essentially eliminates all motion blur on the lcd as long as you have a source outputting enough frames. I was immediately concerned that MAME couldn't take advantage of this until I found that someone made a patch that does just that. Apparently it also helps a bit for input lag by halving the frame buffer (I think? I read pretty quick).
Relevant links:
http://www.blurbusters.com/software-bas ... y-in-mame/
http://forum.arcadecontrols.com/index.p ... 710.0.html
Anyway, I was wondering how this would affect playback/recording. Has someone tried for themselves?
If it doesn't break recording maybe we can say pretty please so Barry will add it to the next wolfmame ;) ?
Re: Removing motion blur for LCDs with MAME
Post by mahlemiut » Thu Oct 17, 2013 11:26 pm
That thread seems to suggest there is less input lag at 120Hz, which would mean that it would make INPs made with that active incompatible.
But if you can operate MAME at 120Hz without resorting to hacking MAME itself, there shouldn't be an issue.
Post by The_Pro » Fri Oct 18, 2013 1:00 am
Yeah, I suspected it wouldn't work out. Guess I have to keep that CRT on the side for a while still as 120Hz without lightboost isn't perfect yet. I see some 240Hz screens on the horizon though. Wish monitor tech would move faster.
