My score of 175K is incorrect(?). The first two numbers (170,000+) I know are correct, but I believe that I mixed up any further ones. So can anyone check the actual score?
dtaber@safeplace.net
I need my New Rally-X score checked... possible mixed up sco
Rather than wait on an editor, why not just play your own recording
back again and edit the score yourself? Those guys have lives too and
there are a lot of recordings that don't get watched for a long
time...
Brian
bmclean84@hotmail.com
time...
Brian
right brian, all uploaders should be playing back a healthy portion
of their own recordings before uploading anyways for further
verification, and perhaps for some knowledge in learning how to play
the game better (why did i die at the one spot?)!
Also, you should playback your own recordings just in case you windup
making a recording that doesn't playback (because the wrong settings
were used) and will get zereoed eventually anyways. If you playback
your recording and notice a failure to playback, you could easily try
a different setting (like removing nvram or turning sound off) and
then you'll get it played back again and when it's uploaded it could
get quickly confirmed.
churritz@cts.com
churritz@cts.com
My score WAS wrong. And I was wrong that the second number was right.
The corrected score is 165,780.
This correction costs me nine LBoard pts.
