Would it be possible to have this game split into regular and dramatic battle modes?
To start a game in dramatic battle mode, insert a coin, hold all three kicks and push start. The first character you choose you will control, the second player you choose will be CPU controlled.
This does not work in SFA2 or SFZ2.
bsr@hnpl.net
Street Fighter Zero 2 Alpha
Well, looking at it some more, it appears that there is no scoring in
dramatic battle mode.
I don't know that should stop it from being split, as it is still a
separate mode of play.
bsr@hnpl.net
bsr@hnpl.net
It should be split into Survival mode rather than Dramatic Battle as
there is scoring in survival and dramatic is pretty easy to beat.
usagi@dingoblue.net.au
Kale, download the sfz2a ROMs from wherever you get them from, then
get the XORs from CPS2Shock. It works perfectly in MAME 0.37b15. As
does SFZ2. It will give give the "this game does not work properly'
message, but that's because the XORs weren't available at release
time.
bsr@hnpl.net
time.
bsr@hnpl.net
