T6 begins !
Moderator: giro-X
lagavulin
T6 begins !
Post by lagavulin »
This message to announce that we'll probably play this 6th MARP tournament from 15th February 2003 to 15th April 2003.
I say probably because we're waiting for Zwaxy's work about the scripts. I think it will be done this week, so the battle should begin Saturday 15th at 0.01 GMT !
I'm on vacation from the 13th to 20th, so I won't be here to answer to all eventual problems. If there are problems, please wait until 21th Feb.
Below is the list of versions of MAME to use and the list of games with their judges and settings.
Have fun !
Versions of MAME : use one of the three versions of Alphamame-063
Games :
1 ) t6-bouldash-pt1
Boulder Dash
Judge : Blost
Play Part 1, Default settings ( normal difficulty, 2 lives ).
Use only the 2 first lives, play is over after the second life.
2 ) t6-dfeveron-ta
Dangun Feveron
Judge : Skito
Play Time Attack Mode ( Insert a coin, then press buttons A and B simultaneously while pressing Play Credit ), Default settings, Use of the Kitty is NOT allowed.
3 ) t6-ffight
Final Fight
Judge : Le Claqueur Fou
Default settings ( normal difficulty , 2 lives, extra life at 100K )
4 ) t6-ixion
Ixion
Judge : Phil Lamat
Default settings ( normal difficulty , 3 lives, extra life every 40K )
5 ) t6-parodius
Parodius Da!
Judge : Gameboy9
Default settings ( normal difficulty , 3 lives, extra life 20K-80K )
6 ) t6-pgoal
Pleasure Goal
Judge : Dax
Default settings
7 ) t6-psychic5
Psychic 5
Judge : Francois Daniel
Default settings ( normal difficulty ), Use only 5 lives, play is over after the 5th life.
8 ) t6-wits
Wit's
Judge : Lagavulin
Default settings ( normal difficulty , 3 lives, extra life 200K-500K ).
Lagavulin,
2003 MARP Tournament Coordinator.
Can alpha64tg also be used ?
lagavulin
Post by lagavulin »
Why not ? No objections for me ... Let's go for Alphamame63 or 64 ( but not 62 ! )
Lagavulin,
sikraiken
Post by sikraiken »
Will I still be able to participate? (I won't be here from the 15th to the 27th of Feb)
Rat
Post by Rat »
How do you select between Boulder dash part one and part two ? I only seem to be able to play part 2 ? yet it lists it as both on the all games list.
Blost
Post by Blost »
Dip Switches->Game (Part1/Part2).
Rat
Post by Rat »
OK thanks Blost.
Also to clear things up
quote
1 ) t6-bouldash-pt1
Boulder Dash
Judge : Blost
The default difficulty is HARD, so I have left that unchanged and changed lives from 3 to 2
Hm.
Default settings on Boulder Dash is: HARD difficulty and LIVES=3.
Do I must change lives to 2 as play only 2 first lives?
HARD = Normal?
I sent inp with changed lives to 2 and unchanged difficulty. Is it good?
lagavulin
Post by lagavulin »
you're right. You have to change the lives settings only.
Lagavulin,
